9 port oliver 88 head
Future 77 pulle
01-15-2008 15:27:47
Building a 340 ci 88. 11 to 1 compression ratio and 3500 rpm. We set the head up in the mill, with a 1-3/8 reamer, ran down into the ports, the head looks great! Id like to go a bit larger on the intake ports, since they are pretty much straight thru,,, can the OD of the intake port go out to 1-7/16 without going thru the casting of the port on a 88 head?? Exhaust is still at 1-3/8 OD now after opening it up,, quite a difference,, but should be enough??
