FARMALL M CARBURETOR
LN
01-14-2008 19:00:12
WORKING ON A CARB FOR A FARMALL M , I HAVE READ ABOUT DRILLING OUT THE HOLE IN THE MAIN FUEL FEED ANF THE TWO BOTTOM HOLES IN THE UPDRAFT TUBE I PLAN ON TAKING THE CHOKE PLATE OUT , AS FOR THE CONNECTOR TUBE BETWEEN THE 2 HALVES I THINK IS CALLED THE VENTURI, CORRECT ME IF IM WRONG , CAN YOU GET A LARGER ONE OR IS SOMEONE SELLING AN AFTERMARKET ONE, IT LOOKS TO ME IF YOU COULD GET A LARGER ONE OR TURN THAT ONE ON A LATHE YOU COULD GAIN SOME HP
