tire size
magg
01-13-2008 19:58:52
Need some help..my WD-45 stripped [no hyd. pump ,PTO shaft or gears ,no rock shaft ,fenders ,or factory drawbar] weighs 3640 with me on it ..tires are 18.4 X 26 ..10 ply combine with very heavy rims..would like to pull 3500 ,4000 ,& 4500# class..stock engine...need advise on tires..have a set of 15.5 X 38 tires mounted on open centers & could weld spokes to 8 bolt center or use factory PA rim & cut out the adj. part & weld spokes in...what size 28's ??also have pressed steel set of 16in. X 34 rim's [no tires]I could adapt..this is to much to think about...thanks for any advice...Marvin
redkev
01-19-2008 05:04:46
 Re: tire size in reply to magg, 01-13-2008 19:58:52
Would you be interested in selling the 34 in. rims? I have been looking for a set of 34's, 9 bolt pattern. Where are you located? If you are interested in selling, e-mail me. Thanks, Kevin
magg
01-15-2008 04:48:26
shutout...why ????
