IH M flywheel clutch
REDWHEELS
01-13-2008 19:36:29
Will a 12 inch clutch and flywheel set up from a later model M tractor fit into a 1940 IH M. I want to run a 12 inch clutch in a M puller if it will work and starter will work etc.
superih
01-15-2008 09:54:42
 Re: IH M flywheel clutch in reply to REDWHEELS, 01-13-2008 19:36:29
Yes, everything should fit, you must use a 12 inch clutch for an M or Super M.
REDWHEELS
01-14-2008 10:33:25
mschultz Did you mean to be sure to check the spline size or ? I would try to use a Super M disc.
mshultz
01-14-2008 12:19:54
 Re: IH M flywheel clutch in reply to REDWHEELS, 01-14-2008 10:33:25
Just make sure the hub from the clutch disc mates the input shaft on your M. As long as you tell them that it is being used in an M they should get it right - the hubs are interchangable with just a few rivets holding them on. It's probably been 10 years or so, but we once ordered a 12" clutch and told them the flywheel was from a 400, but we didn't specify that it needed an M hub and I think it came with a 400 hub and it didn't match up properly. I don't recal what the problem was - either diameter or number of splines - but it didn't fit our M input shaft. It wasn't a big deal to get fixed, but it set us back a week or two until they got them matched up. Should be fairly straight forward to get done - just give them all the information.
Good luck.
mshultz
01-14-2008 04:19:36
yes. Just make sure center hub of clutch plate is correct.
