what is the best size rim?
dan osborne
01-13-2008 18:26:47
Want to run 16.9 x 34 tires on a UTS Moline. Shooting for the 5500# plus classes in div. 2. I have turned down my stock hubs for 9 bolt wheels. Would like to know what you guys think is the best width rim for these. I have a set of 16" wide steel wheels I bought to run 18.4 x 34's, but decided to run a lower weight class as the motor is stock. Are these too wide? What should I run? Any advice would be much appreciated as I am new to pulling.
JPatton
01-14-2008 19:34:32
 Re: what is the best size rim? in reply to dan osborne, 01-13-2008 18:26:47
Dan - Well if you are going to run a true Div. 2 class, the rules say the widest rim is the one printed on the side of the tire. Every 16.9X34 tire I have says 15 inch rim right on the tire. You had better look at your tires to be sure.
Hope this helps
Puller1
01-14-2008 18:30:36
use the largest possible tire that the rules state, also the 16 inch rims will work great with the 16.9 tires
Pulling 88
01-14-2008 16:22:59
I would go with the 16-34 as that is what i run my 88 ollie with and have had great success
