building a pulling tractor
midwest farmboy
01-13-2008 15:21:46
I am wanting to build a pulling tractor that I can pull in a antique class (1958 and older) and in the local farmer classes. I was wondering if you gays had any suggestions or what tractor I should look for. Preferably a john deere but you might be able to persuade me to something else.
apz*jr
01-15-2008 13:20:55
 Re: building a pulling tractor in reply to MJF, 01-13-2008 15:21:46
midwest farmboy said: (quoted from post at 16:21:46 01/13/08) I am wanting to build a pulling tractor that I can pull in a antique class (1958 and older) and in the local farmer classes. I was wondering if you gays had any suggestions or what tractor I should look for. Preferably a john deere but you might be able to persuade me to something else.
What class do you want to pull in? depends...
Dustin Hill
01-14-2008 14:49:37
 Re: building a pulling tractor in reply to midwest farmboy, 01-13-2008 15:21:46
it just depends on the class you want to pull. i pull with OTTPA here in North Carolina with a 900 Ford. with 38" tires they are almost impossible to beat in 4200 thru 5700 pounds. They have 45 horsepower stock and also turn 2450 rpms stock.
Your Mentor
01-15-2008 07:41:43
 Re: building a pulling tractor in reply to Dustin Hill, 01-14-2008 14:49:37
Untill that "A" from Mornoe shows up.
Dustin Hill
01-15-2008 16:23:33
 Re: building a pulling tractor in reply to Your Mentor, 01-15-2008 07:41:43
yea but after that lil ole ford stomped that "A" it went back in the shed for an overhaul!! haha
Big Jake 60
01-14-2008 14:39:08
If you don't mind pulling heavy a JD 60 will do a good job, I't will be slow but it will be fun. with a good tune up on a stock one you'll not run out of power very often and every now and then you'll hurt them bigger motors feelings. Berry Funderburk
KY Case Guy
01-14-2008 12:41:40
If want to do it for fun by a JD, if you want to win get a 6 cyl. 460,560 IH, Case 600,900, or any of the big Molines. You can come across alot of tractor missing part,etc. I would find something like that to make a puller out of rather than tearing up a restorable tractor, especially if it's kinda rare. Later...
jd b puller
01-14-2008 11:33:06
 Re: building a pulling tractor in reply to TVMAN, 01-13-2008 15:21:46
midwest farmboy said: (quoted from post at 19:21:46 01/13/08) I am wanting to build a pulling tractor that I can pull in a antique class (1958 and older) and in the local farmer classes. I was wondering if you gays had any suggestions or what tractor I should look for. Preferably a john deere but you might be able to persuade me to something else.
No gays here, but if you're on a budget, a late model A or B works good for the Deere side. Geared low, so you don't need tons of power. Takes more skill, and luck, but can work.
560 Farmall Puller
01-14-2008 10:44:26
Another vote for 460 or 560. You can get a fair amount of HP by just putting an 806 block in one.
Weldin man
01-14-2008 09:55:12
COCKSHUTT !!!!!
okie puller
02-23-2008 10:03:55
 Re: building a pulling tractor in reply to Weldin man, 01-14-2008 09:55:12
what do you need to now 918-269-0590. I have two cockshutt pullers.
John B. NE Ind.
01-14-2008 09:05:55
We have 2 Moline 445's we pull. Ours and uncle Earls. We pull them mostly in the 4000#-6500# classes.They usually do pretty well. One thing these tractors have is the hy-lo trans which gives us a gear that works on any track.We don't shift gears when we pull but depend on gear selection to match track conditions. Our Ford 600 has the over-under-direct and we can do the same with it. We pull div-2 and before we sold the WC Allis we had it was tough to find just the right gear. To high a gear and you'd run out of snott at the end. To low a gear a you might power out to soon and burn off the tires. With the Ford or Moline you could grab that inbetween gear. You could buy a 445 with decent compression and do a little head and carberator work, tweek the govener, and for less than $800 extra make it compeditive in most areas.
PGpower
01-13-2008 17:13:40
About any brand can be fun to make into a puller. I personally have a Moline U and they make good pullers. I would say you can't go wrong if you get any of the following: JD B, A, or G. Farmall H, M, 400, 460, 560 (you will need ChadS magically springs for the H or M!!!) AC WD45 (I am not real familiar with all of the AC's that make good pullers), Moline U, G, GB, 5-Star, Oliver 77, 88. There are more than the models I listed, but these seem to be the most popular. Depends on what weight class you want to pull and your brand perference. Just decide those two things and start the addiction.
Craig-NC
01-13-2008 17:26:31
 Re: building a pulling tractor in reply to PGpower, 01-13-2008 17:13:40
AC WC makes a light tractor that you can get an E gleaner engine into to get hp...WD and WD-45 are the best to put motors in and still weigh light, around 4,500
NE NEB FARMALL
01-13-2008 17:10:51
Depends what class you want to pull in. I would research the local pulling groups in your area and see what class you want to pull in. I am new and I bought a Super H. In Neb H's and H parts are pretty easy to come by.
560 puller
01-13-2008 16:04:16
Oliver 77 or a farmall 460/560 make nice pullers.
But thats just my opinion.
