Stroke between mild wild
A info?
05-04-2001 11:02:17
Alright John Deere unstyled A pullers; we need a little info if anyone is willing to share. Will 8 or 8.25" stroke fit into an A without knocking the back out and grinding the cam very much. We want to put one together without a ton of grinding. What are your recommendations.
al
05-05-2001 19:14:32
 Re: stroke between mild wild in reply to A info?, 05-04-2001 11:02:17
I did a 40 A @ 8 inch without going through.I think I had to sand a little off the casting wall. This was with stock A rods .you could get a set of offset welded rods and go bigger.
US APuller
05-05-2001 17:47:31
I have a 37A and the most I could go without knocking the back out was 7.5in. Plus I took alot off the cam.
Caseman
05-04-2001 17:11:08
Leave your styled A the way it is and still kick our butts :) . Just kidding with ya.
Bob
05-06-2001 06:56:52
 Re: Re: stroke between mild wild in reply to Caseman, 05-04-2001 17:11:08
We have a 36 A with 8" stroke and the case is not cut out and it still has the JD rods in it.
