8060 HEAD MODS
LN
01-04-2008 19:13:09
REBUILDING AN M GOING WITH STEPHEADPISTONS 4.125
LOOKING FOR ANY IDEAS ON CAM AND WHAT TO DO WITH AN 8060 HEAD TO MAKE PULL GOOD SPRINGS, VALVE SIZE ?
Charles E. McNelly III
01-05-2008 06:02:58
 Re: 8060 HEAD MODS in reply to LN, 01-04-2008 19:13:09
Which 8060 head do you have?
Charles
LN
01-05-2008 08:42:08
 Re: 8060 HEAD MODS in reply to Charles E. McNelly III, 01-05-2008 06:02:58
what are the differences, I was wondering if putting in bigger valves was worth the time and effort and if you should run a stiffer spring,I can do the machine work myself I work in a machine shop. also trying to decide on how much to machine off and still have reliability.
and any input on a good cam THANKS
james rumph
01-05-2008 04:39:31
Have it Magna Fluxed for cracks first ! "Alot" of them crack down thru the valve seat . I bought a 450 gas head for my Super M because my 8060 head was cracked in 6 spots . By the time you repair it and do it up it is still cheaper to get a better head .
The 450 gas head is cheaper then the LP head and has a smaller cumbustion chamber then a 8060 with out cutting it .[ Higher Compression]
I went threw waynesrepair.com and they supplied everything ! I had it ported , flowbenched , new valves, springs ,guides the works . All your power is made in the head , spend your money on it .
Give Waynes a look , i'm very pleased with the work they did at a great price .
