Who has the strongest G John Deeres?????
n.carolina
01-04-2008 16:06:11
What division do they pull in and what kind of horsepower do they have????
green with envy
01-08-2008 16:46:53
 Re: Who has the strongest G John Deeres????? in reply to n.carolina, 01-04-2008 16:06:11
who cares the little g's in the valley can't run with the big bad oliver 880!!!!!
Travis Grant
01-09-2008 06:25:59
 Re: Who has the strongest G John Deeres????? in reply to green with envy, 01-08-2008 16:46:53
HA, what are you talking about? If this is the 880 I know of, then I think it is funny how two people have to own that tractor. Which part do you own? The engine or the tractor? At least David and Barry own the WHOLE tractor, not just half of them!
green with envy
01-09-2008 16:19:24
 Re: Who has the strongest G John Deeres????? in reply to Travis Grant, 01-09-2008 06:25:59
I don't own any part of the tractor I live in Madison. I know the 880. Barry and David can't
run with the real green and you can't either if you even have a tractor little boy!!!!
Travis Grant
01-09-2008 18:02:10
 Re: Who has the strongest G John Deeres????? in reply to green with envy, 01-09-2008 16:19:24
Dont let your head swell up. Just remember, there is always something out there that can beat it!
Travis Grant
01-09-2008 18:12:14
 Re: Who has the strongest G John Deeres????? in reply to Travis Grant, 01-09-2008 18:02:10
I will give them boys one thing, I've seen the 880 run and it does pull well. It does better in the classes where they can run any speed not in the 6 mph class. You must have seen it pull with the cvatpa pullers. Never been to the cvatpa pulls before but I hope I can go this year!
doug boll
01-07-2008 11:45:40
around here Mark and Al Shellum, Al's unstyled G is pretty impressive not to mention Kent's A at over 800cubes! NO KIDDING!
buickanddeere
01-06-2008 16:25:27
Kind of amazing what some guys can get from a engine designed to plough the back 40 acres on left over oil fuel the refineries thought near worthless. While running at 975 rpm maybe making 40HP with a tail wind, using 4 to 1 compression and long, small dia heated intake passages.
BigRed400
01-05-2008 09:09:00
8200 and up the Franklin's in and around Vale area that pull regular,nice family or group of folks, very tough tractor but also have a lot of money in that tractor
afer
01-08-2008 20:15:20
 Re: Who has the strongest G John Deeres????? in reply to BigRed400, 01-05-2008 09:09:00
where in Vale, what state?
BigRed400
01-10-2008 14:41:32
 Re: Who has the strongest G John Deeres????? in reply to afer, 01-08-2008 20:15:20
Northbrook N.C.
2 Cylinder
01-06-2008 06:19:45
There are several good running G's/70's in the state of Michigan.
Travis Wilkins
01-07-2008 15:26:22
 Re: Ole Tater in reply to 2 Cylinder, 01-06-2008 06:19:45
Its not a G but it runs like one, that would be "Ole Tater Digger" "Super" A from back in the mountains of Virginia!
superih
01-07-2008 13:46:56
 Re: Who has the strongest G John Deeres????? in reply to 2 Cylinder, 01-06-2008 06:19:45
Tom Chapman in Michigan has one of the smoothest running G's, for its size, that I have saw pull. He can usually do pretty good too.
Valley Puller
01-06-2008 16:24:18
Barry Parkinson's JD G in the Shenandoah Valley, Virginia
Jason Grant
01-06-2008 18:47:25
 Re: Who has the strongest G John Deeres????? in reply to Valley Puller, 01-06-2008 16:24:18
David's Unstyled G isn't no slouch either!
Jeff A. Gravert
01-30-2008 21:41:09
 Re: Who has the strongest G John Deeres????? in reply to Jason Grant, 01-06-2008 18:47:25
Shellum"s, hands down no contest. Ya, Kent helps build and his A is amazing but you were talking about G"s. Oh, wait a minute, Kent"s A is a big as most ordinary pulling G"s.
