9 bolt wheels
Wayne May
01-01-2008 19:03:34
Where is the best place to buy 14x38 pressed steel wheels for my tractor?
Thanks
Wayne May
01-02-2008 08:27:35
 Re: 9 bolt wheels in reply to Wayne May, 01-01-2008 19:03:34
Im in Virginia.
Thanks
mshultz
01-02-2008 11:58:11
 Re: 9 bolt wheels in reply to Wayne May, 01-02-2008 08:27:35
Depending on where you are in Virginia, there is a place called Barrick's Tire in Newville PA - about 35 minutes north of Maryland line on 81. Centers go for around 150, and the rims probably about 140ish. You need to weld the centers in where you want them.
Just Glory
01-02-2008 08:22:38
When you need something your location means a lot as far as shipping cost and the cost of anything. Just the general area is all that's needed.
jeremys108
01-02-2008 06:26:39
Where are you located? I have a set of like new 14x38 pressed steel wheels.
Jim Johnson
01-02-2008 02:12:37
Where do you live?
Jim
Jim Elder
01-01-2008 19:24:37
M.E. Miller Tire Wauseon, Ohio 800-621-1955,ext.4
www.millertire.com
