tires
jesse allen
01-01-2008 18:49:35
Does top cutting tires make that much of a difference?
rich4
01-02-2008 10:12:35
 Re: tires in reply to jesse allen, 01-01-2008 18:49:35
ALso new to pulling, what is top cut? cutting lug edges or what exactly? Thanks
Mike Aylward
01-02-2008 06:15:12
Most people don't realize that top cutting doesn't only sharpen the leading edge of a tire somewhat but also "opens up" the tread. Uncut tires top edges line up, causing a lack of traction on pulling tracks that are not softer like field conditions (for which the tire was designed). A top cut tire turns the tire into a "sawtooth" pattern which drastically helps traction. It is this cut which does the most good, not just sharpening the front edge. I always shake my head when associations say "no cut tires" but allow a top cut. It's not just the front edge of a cut tire that helps. Why not just allow cut tires and be done with it? Mike
mEl
01-03-2008 03:59:47
 Re: tires in reply to Mike Aylward, 01-02-2008 06:15:12
That is a good description put forth by Mike, the only thing I can add is that cutting new tires with a full height tread will still not make a good pulling tire, in my opinion the best tire is one that has been aged and the tread hardened by time or a hardening process. Also for our tractor tread height of 1/2" to 5/8" seems to work the best on any track, My personal belief is that the more power one has the less tread height you need. We still run a pair of 18/4 x38 Armstrongs on 20 in rims on the ole DC that we cut back in the 70's, just touch them up occasionally. We do well in this area in more open style pulls, starting in 4500 lbs and up to 6500.
in the back
01-02-2008 19:08:56
How do you cut the tire?
For a top cut , do you just take a planer and cut it so the front is higher than the back.
Could somebody post some pictures or front and top cut tires. And explain how they do it.
mEl
01-02-2008 03:46:46
Go to the pulls and watch the winners and look not only at the cut but the height of the tread and hardness of the rubber. people that win have it figured out for you, all you have to do is pay attention. If you are asking this question you are new to pulling, c,mon in and join one great sport, great people, lots of collective knowledge on this forum, all you have to do is tap into it, most are eager to help. mEl
Dieselbear
01-02-2008 16:08:02
 Re: tires in reply to mEl, 01-02-2008 03:46:46
Is this mEl from Pa? Glenn
mEl
01-03-2008 03:44:26
 Re: tires in reply to Dieselbear, 01-02-2008 16:08:02
Glenn, yes
Dieselbear
01-03-2008 19:46:31
 Re: tires in reply to mEl, 01-03-2008 03:44:26
How are you? haven't talked to you in a coons age. My E-mail open
