460 TA SLIP
turbo460
12-30-2007 21:32:15
Can a T/A in a 460 Ih slip on the high side or only on the low side. Not familar with the complete workings of this unit.
digger 856
12-31-2007 09:23:13
 Re: 460 TA SLIP in reply to turbo460, 12-30-2007 21:32:15
it can slip on either side
high side ta clutch
low side roller ramp or sprang bearing
FARMALL PULLER
12-31-2007 07:11:11
I think if you have slippage on the high side, it will be the main clutch.
Kevin Meier
01-05-2008 06:44:03
 Re: 460 TA SLIP in reply to FARMALL PULLER, 12-31-2007 07:11:11
If it"s the main clutch it would slip on either side? I have a 9 spring t/a clutch with a metallic disc on hand. Email me if you may be interested.
Kevin
