pulling gear
moline puller
12-30-2007 15:51:46
Does any one have a splitter gear that is bigger than forth gear for a MM GVI. Forth gear isn"t big enough. Thanks
doc joe
12-31-2007 18:30:59
 Re: pulling gear in reply to moline puller, 12-30-2007 15:51:46
We made first gear into 4.25 or 4.50 what ever works for you. pro fab in wisconsin made them. I dont have any thing now Begeman may have contact him. Hope this helps joe.
jd b puller
12-31-2007 10:11:12
what size 38? Several models are similar in width but taller...
How about a shorter tire and go up a gear? Tires are easier to find than gears, and a lot less work to swap.
AC
12-31-2007 04:05:08
I wonder if 4th out of a 5 star would fit. Its alot stiffer than M5 - G1000 ..?
moline puller
12-31-2007 10:06:51
 Re: pulling gear in reply to AC, 12-31-2007 04:05:08
Is forth gear in a five star bigger than forth on a g series rearend.
AC
12-31-2007 15:31:06
 Re: pulling gear in reply to moline puller, 12-31-2007 10:06:51
4th gear in a 5 star with 15.5's was like 12 mph at 1650 rpm's. Yeah, very very tall! I'll be taking one out of my 5 star before too long, if I can get to it.
Solid Junk
12-30-2007 19:42:44
I think Begeman had some gears. I don't have any contact info.
jd b puller
12-30-2007 19:04:11
How about a taller tire?
moline puller
12-31-2007 10:09:01
 Re: pulling gear in reply to jd b puller, 12-30-2007 19:04:11
I already am running a 38" tire
