oliver waukesha engine
pitch fork
12-26-2007 09:34:27
there is a waukesha engine that is a 135 and is 426 ci stock, does any body know if it will fit in a 880 frame? it is a K series
eric bloom
12-31-2007 22:24:01
 Re: oliver waukesha engine in reply to pitch fork, 12-26-2007 09:34:27
we have a 135 waukesha. i looked at it. i dont really think it will fit i believe the bolt pattern is different and the motor is just alot bigger.
BM
12-27-2007 17:32:02
I seen a 135 once, pretty sure we came to the conclusion that the bolt pattern was the same to bolt it in. no promises. with those rules i'm pretty sure i'd build a frame and run a 600 inch 478 herc on gas with aluminum heads and lifters that have wheels on em :). then turn it 7500.
pitch fork
12-27-2007 17:54:30
 Re: oliver waukesha engine in reply to BM, 12-27-2007 17:32:02
Thanks for the infomation, I owe you one
Maybe
12-26-2007 19:48:05
what kind of puller are you building
BIG POLE barn
12-27-2007 15:41:32
 Re: oliver waukesha engine in reply to Maybe, 12-26-2007 19:48:05
do you always answer questions with questions???
pitch fork
12-27-2007 08:52:34
its a open class, no rules, no bitching or winers aloud. So do you know th answer or not?
jjon
12-27-2007 11:03:59
 Re: oliver waukesha engine in reply to pitch fork, 12-27-2007 08:52:34
Just the kind of attitude that will get you no help!
pitch fork
12-27-2007 11:22:19
 Re: oliver waukesha engine in reply to jjon, 12-27-2007 11:03:59
not too worried, I dont think any body knows on this site any way.
JOE ZIP
12-27-2007 12:50:24
 Re: oliver waukesha engine in reply to pitch fork, 12-27-2007 11:22:19
well you will probably never find out will you?
pitch fork? is that your job title?
