Farmall C-301 tractor block vs IH 264 industrial
kam
12-23-2007 05:46:57
Are the C-301 tractor block and IH 264 industrial blocks interchangeable? Was bone-yard scavenging and the owner wanted to sell one that he swears interchanges. I saw some differences, but they do look similar.
Anyone know about these?
Buzzman72
12-23-2007 11:11:25
 Re: Farmall C-301 tractor block vs IH 264 industrial in reply to kam, 12-23-2007 05:46:57
If the "industrial" motor is based upon the Black Diamond [BD] 264 truck motor, lots of stuff will interchange with the C-301. There were two possible heads, the "straight valve" and the "tilt valve", on the truck motors. Straight-valve motors were prone to dropping a valve occasionally; the tilt-valve engines were not. Piston tops were different between the two as well,so if you build one, make sure you're getting pistons compatible with the head you have.
kam
12-24-2007 04:37:08
 Re: Farmall C-301 tractor block vs IH 264 industrial in reply to Buzzman72, 12-23-2007 11:11:25
Thanks,
We bought a straight valve head from this junkyard and will use it on a C-301 powered Farmall 460 puller. We will be porting the head and switching over to 11/32" valves and performance springs, retainers, locks etc...
I wouldn't mind having a couple blocks around to sonic test and pick the best one to bore out.
