What piston is better
diocona
12-21-2007 14:58:56
Should i buy a set of used m & w power pistons & 3 7/16th sleeves in good condition or is it better to buy new stepped head tisco pistons, Where can i fine new rings for M&W pistons. This is for a 1944 Farmall h puller. Please give help asap.
kam
12-22-2007 04:54:27
 Re: What piston is better in reply to diocona, 12-21-2007 14:58:56
They might be on this websites store at the link below
kam
12-22-2007 04:51:15
Since nobody answered yet. I would rather have new fresh sleeves for the best ring seal than used sleeves any day.
The hastings catalog has 4 listings for 3-7/16"s bore M&W sleeve kit. I cut and pasted below, but it will be hard to read.
You need to go to the hastings catalog and pick the one that matches the ring package on your piston.
I put the link below (it's the INTERNATIONAL - Case tractor section)
3 7/16 4 2C7681 12 - 3/32 4 - 1/4
C152 Engine (Sleeved Engine)
International Model H Kit
M & W Sleeve Kit #SP4, 5
Superior Piston #A1019
Allied Sleeve Kit #WSA302, 303
Ertel Sleeve Kit #SA209, 210
Genuine Kit #S161, 164, 168
Sterling Piston
M & W Sleeve Kit #SP70, 71, 72
Power Pkg. Increased Bore Kit Kerosene Eng. 3 7/16 4 2C7790 8 - 3/32
4 - 1/8 4 - 1/4
Sterling Piston
Power Pkg. Increased Bore Kit Kerosene Eng. 3 7/16 4 2C7585 12 - 3/32 8 - 3/16
Sterling Piston
Power Pkg. Increased Bore Kit Kerosene Eng. 3 7/16 4 2C5669
5669 12 - 3/32 4 - 1/4
For piston ring you can find almost anything by ring dimension. Here are two more resources I use.
Total Seal 800-874-2753 (Keith Jones)
Akerly & Childs at 661 702-1999
I can order you any Hastings if you have trouble finding it locally.
kam
12-22-2007 09:34:42
 Re: What piston is better in reply to kam, 12-22-2007 04:51:15
That link doesn't work. You have to go to master catalog, then drop down to: "INTERNATIONAL-Case tractor"
Master Link below
