6.5 pistions
cabbage
12-17-2007 18:58:32
Hey wonderin if any one knows where to get 6.5" pistions for an A w a jacks block. Are early D pistions that size? Or Do i need to have them custom made?
Bigmotors
12-17-2007 22:33:10
 Re: 6.5 pistions in reply to cabbage, 12-17-2007 18:58:32
Power Block Pistons for a "G"
"70" Power Block Pistons (alot shorter)work nice- but you want to make sure to check them out for stress cracks around the rings and pins.They have a bad history for this.
Mike n Mo
12-17-2007 20:17:29
Try Murphy's Motor Service. I got a set of large bore billet pistons for a Deere from them, very pleased with the quality.
jd b puller
12-17-2007 19:43:38
Assuming you've got a stroker crank, the D pistons are going to be waaaay too long. You'll need to use something shorter (and lighter).
What do you need for Comp Height, pin dia, top ring land? They'll almost have to be billet.
Have you made your rods yet?
cabbage
12-20-2007 13:46:47
 Re: 6.5 pistions in reply to jd b puller, 12-17-2007 19:43:38
no not yet just tryin to gather some ideas and get some sorta plan together.
