stroker crank and rods
kam
12-17-2007 18:11:18
Shopping for cranks and rods. talked to jeff murphy and his products look good, but want to check out a few others.
Need 5" or possibly a 5.250 stroker crank and rods for an IH 301
Craig Standish
12-20-2007 07:22:57
 Re: stroker crank and rods in reply to kam, 12-17-2007 18:11:18
There is a place in Grant Park IL. that is making my rods right now. They make billet or steel mine are 720.00 for a set of 4.
AC
12-20-2007 09:11:52
 Re: stroker crank and rods in reply to Craig Standish, 12-20-2007 07:22:57
Is his name Ryan?
Craig Standish
12-20-2007 07:24:28
Sorry The name is R&R 815-465-6741
Engine Builder
12-17-2007 19:53:19
Why not give Gilly a call @ moldex?
AC
12-18-2007 05:04:56
 Re: stroker crank and rods in reply to Engine Builder, 12-17-2007 19:53:19
Who is this "Moldex"? 2500 for a billet 4 - 6 cyl crank does not sound that bad...
kam
12-18-2007 15:03:21
 Re: stroker crank and rods in reply to AC, 12-18-2007 05:04:56
Moldex has been around for a long time, one of the first billet crank makers. They charge around $2500 for a domestic v8 billet crank.
I'm not sure how much a tractor crank would be. Might depend on if they already have prints and how big a steel billet they start with.
Phone: +1-(313)-561-7676 Fax: +1-(313)-561-0724 Address: 25229 W. Warren St., Dearborn Heights, Michigan 48127, USA
AC
12-19-2007 04:51:14
 Re: stroker crank and rods in reply to kam, 12-18-2007 15:03:21
Thanks!
kam
12-19-2007 14:06:06
 Re: stroker crank and rods, MOLDEX in reply to AC, 12-19-2007 04:51:14
Well, I called Moldex and a tractor crank is a whole different thing from a V8 Chevy.
He said an inline six is a lot more work than a V8. With the length and stroke a big chunk of 4340 billet is needed to start with. They estimated A 5.25" stroke Billet crank for the 301 would be between $4300.-$5000.
They would need a sample stock crank sent in for an exact price and for the set up dimensions.
A 4cyl might be less,(more like a V8) but I didn't ask.
kam
12-17-2007 20:36:02
I'm not sure a $2500 billet crank is in the budget, but it's nice to know that someone is willing to make a crank for that engine.
I was thinking a worked stock crank with decent rods are in the budget.
What they did now is offset grind the rod journals 5/8" to make a 5" stroke using a Farmall A rod with a 1.75 journal. kinda sketchy, esp for a four main bearing engine. The rods aren't holding up that well either.
Thanks
Just Glory
12-17-2007 19:18:33
The previous was an unpaid advertisement.
kam
12-17-2007 19:41:48
 Re: stroker crank and rods in reply to Just Glory, 12-17-2007 19:18:33
What does that mean?
I called murphy and got a price and some info.
I'm planning to call Cunniham for rod prices too.
Both the above are high dollar parts (the rods)
I want to know who else to check out. I build automotive engines, but not tractor pullers till now.(and maybe just this one) I figure you guys have the lowdown.
thanks
Charles E. McNelly III
12-18-2007 18:01:48
 Re: stroker crank and rods in reply to kam, 12-17-2007 19:41:48
The sad truth is that you can buy a complete stroker assembly for a small block chevy cheaper then getting a old,used,welded up, just mabe it will hold crank for a farmall. go figure. I think the pullers are the ones whos getting stroked. JMHO
Charles
kam
12-19-2007 03:00:39
 Re: stroker crank and rods in reply to Charles E. McNelly III, 12-18-2007 18:01:48
Charles, Very true.
I think I WILL call Moldex before making a final decision on the crank.
