MW piston set for a 560 puller.
Red Ned
12-17-2007 09:27:06
Will these give a man much more power over a stock set? I have found a set i would like to get to put in my 560. They have the dommed pistons. Im just looking to get some more power as cheap as i can and my motor is needing a oh anyway. thanks Red Ned
trulyred
12-19-2007 17:36:30
 Re: MW piston set for a 560 puller. in reply to Red Ned, 12-17-2007 09:27:06
You probably will only see an increase of 10%, 15% at the most and there"s always carburetion and timing changes that must be made. So if you have 60hp. you might get 75 with the M&W"s when its all said and done.
trulyred
12-19-2007 10:00:32
I would like to talk to you about the M&W sleeve & piston set! My email is open or call 812-328-6126. Thanks.
Red Ned
12-19-2007 12:04:47
 Re: MW piston set for a 560 puller. in reply to trulyred, 12-19-2007 10:00:32
I dont have them they are on a auction. Have you ever used a set of these? If so do they make a big diff? thanks
