heavier clutch for a 88
Furure 77 pulle
12-14-2007 06:33:17
What pressure plate interchanges with a 88 for a higher hp engine? Or can a 88 be built heavy enough to handle a bigger engine?? Bout 120 hp. Thanks
Ed Hodge
12-14-2007 15:42:34
 Re: heavier clutch for a 88 in reply to Furure 77 puller, 12-14-2007 06:33:17
1650 clutch will hold up
Future 77
12-14-2007 16:24:31
 Re: heavier clutch for a 88 in reply to Ed Hodge, 12-14-2007 15:42:34
Thanks Ed! Ill pick one up! Id imagine it bolts right up to the 88 flywheel?? Been looking for a bearing part number too,, for the brake pinion shafts,, actually its the bearings that sit on the ends of the carrier shaft, that the pinions slip over top of,,, has some shims there too,,, they look a little rough and wanting to replace them, or make bushings to eliminate em.
Cody Adgent
12-15-2007 19:50:42
 Re: heavier clutch for a 88 in reply to Future 77, 12-14-2007 16:24:31
An 880 industrial clutch will bolt right to an 88 flywheel and will hold 120HP out of the box. Last one I bought from Hi-Capacity was around $225 or so.
