BIG 5 STAR
EXTREMIST
12-13-2007 20:40:58
What is the best crank case to use on a really big 5 Star? It may see a beating every now and again so I want to start with a tuff one! Any help would be great
KLS
12-18-2007 10:47:12
 Re: BIG 5 STAR in reply to EXTREMIST, 12-13-2007 20:40:58
How much does a set of blocks like that go for?
KLS
12-18-2007 10:46:58
AC
12-14-2007 04:58:07
336A4A
EXTREMIST
12-14-2007 11:31:37
 Re: BIG 5 STAR in reply to AC, 12-14-2007 04:58:07
what model tractor would that be from?
12-14-2007 14:23:26
 Re: BIG 5 STAR in reply to EXTREMIST, 12-14-2007 11:31:37
How big are you planning? 700+?
AC
12-14-2007 15:14:34
 Re: BIG 5 STAR in reply to ??, 12-14-2007 14:23:26
700 is done all the time. Try for 780 + 800. Will it be NATPA legal?
12-15-2007 20:05:01
 Re: BIG 5 STAR in reply to AC, 12-14-2007 15:14:34
Sorry AC, didn't know you were the foremost expert on building big 4-cylinders...If you could explain 800+ and reliable/Division IV legal, I would be impressed...Good Luck and don't say Doug Henderson could do it, because it hasn't happened!
MnM44
12-16-2007 06:31:59
 Re: BIG 5 STAR in reply to ??, 12-15-2007 20:05:01
Maybe you should read a little bit closer. He says 700 is done all the time and he should try for 780 to 800. Not only could DH build one he is currently doing just that. 6 inch bore x 7.125 stroke and it will be in a 5 star and it will be Div 4 legal and it wont cost 50,000 like the one being built in MO.
Iowa puller
12-18-2007 11:08:25
 Re: BIG 5 STAR in reply to MnM44, 12-16-2007 06:31:59
Give a monkey a mill and he can do better work than DH.
Mopower
12-18-2007 15:31:36
 Re: BIG 5 STAR in reply to Iowa puller, 12-18-2007 11:08:25
Not only is DH pretty handy with a mill but he"s also pretty skilled with the dyno. I"ve seen way too many of his big engines go literally hundreds of hooks with little or no trouble whatsoever. He will also build as big or as small as you can afford and his rates are reasonable.
He stands behind his work (which is risky after watching the way pullers drive and tinker). I"m glad I gotten to know him and grateful for his assistance on our penny pinching puller UB even when he had much bigger projects to work on.
You can e-slam Henderson Power all you want. DH will get more of my business. I say, as an engine builder and a friend, they don"t come much better.
Ethan Berry
The Mopower Ranch
Vermontville, MI
MiHpuller
12-18-2007 11:37:15
Oh, someone gave you a mill to use, then?
AC
12-16-2007 15:26:12
You cant do that!! Mr Question Mark said it cant be done! Obviously he must feel like he is the expert, since I must have stepped on his toes. Dunderhead!
AC
12-16-2007 05:22:30
At least I put my name down, Mr question mark. 6" x 7.5. The rod ratio would suck, but you could get Dieselbear's solid blocks and go to a 6" bore, for 849 cubes. I'm sure he would be happy to sell you a set. I think there are a new guys in NATPA running them. If you wanted to run water, 5.75 x 7.5". for 780 cubes. There are a few out there with ALOT of pulls on them. No one said anything about dependable, but I bet it would be more rugged than some of the other stuff out there. The original poster was "EXTREMEIST" so, I figured he wanted to know what "EXTREME" cubes were. Maybe he'll decide to spend a buck, and go big. If it does not have to be NATPA legal, your numbers would get alot better by using G blocks or 800 blocks, but since the NATPA has a slant against Molines, your screwed. But, I am no expert, and I didnt mention any names. Sounds like someone has a little axe to grind.....AC
Dieselbear
12-14-2007 14:25:24
The late model 670 diesel
Jeff A. Gravert
12-16-2007 07:37:10
 Re: BIG 5 STAR in reply to Dieselbear, 12-14-2007 14:25:24
Dieselbear, what do you have available for blocks?
