1650 oliver
jim michael
12-12-2007 03:21:29
Has anyone put a turbocharger on a 1650 direct injection oliver motor. Is there any special things I need to do or just bolt on. What make turbo did you use or would you use. Thanks for any information in advance.
ejr-IA
12-12-2007 14:16:40
 Re: 1650 oliver in reply to jim michael, 12-12-2007 03:21:29
Have one on mine.Depends on whether you want to do a little butchuring on hood for clearence and holes for the air cleaner and exhaust.Parts off a 1855,1950T or 1955 will bolt on.I didnt want that so I took parts from a M&W turbo kit off a 706 IH or 656 IH and used most of the whole kit .Left the factory air cleaner in place and made new 3" elbows and tubeing to the turbo inlet.Then on the exhaust manifold you will have to hog out the two peace divider runners so the exhaust comes out in one flow instead of two and some grinding on the M&W mounting plate.Also bore a couple new holes in the M&W mountig plate to match the Oliver manifold .Then you have to make a outlet from the turbo over to the intake manifold.You can use the M&W turbo that came with the IH kit but I used a Air research TO4 off a XT 190 or 200 AC.Sounds simple doesn't
