ChadS
12-07-2007 07:19:27
Re: IH 460 Factory Weights in reply to doorman, 12-04-2007 19:19:07
The 460 I had had the front suitcase weight bracket, same as used on up to a 1456. Im not saying its the correct one, but it did, bolt right up and had a IH part number,, whether it was for a 460 or not,, dont know,,, I was thinking if it had the cast wheels like the H or M it would use the same wheel weight as the H or M,,, the 300,350, 400-450 had the slab weights that bolted to the frame rails, and had a pin that slid thru the very front of the bolster,,, 2 or 3 piece set,,, 450-560 did not use this style of weights,, (like the 300-450) the bolster did not have the places for the pins up front,,, Just my opinion, thought that if the IH weight bracket bolts right on to the nose of that 460,,, with no alterations, you SHOULD be allowed to use it. See, in our club, farm stock did not used to be able to use suitcase weights,,, well, the 560 had the front weight bracket like the newer 56 tractors,, and used suitcase weights, factory, well they kept the year break right up to the 1957 break to keep the 460/560 out to eliminate the conversation. Now, we use suitcase weights,,,, but, still, they are afraid of the 60 series tractors at their little pulls. Anyways, If it bolts on, and you did not have to alter one darn thing to use it,, I say, well I said that already didnt I?? JMHO, ChadS [email protected]
