fuel injection
smdv806
12-04-2007 17:10:09
Ok how do I setup fuel injection on a 560 gas? What is involved in the conversion? I am going to run a small turbo and run about 10 lbs of boost.
buickanddeere
12-08-2007 19:41:31
 Re: fuel injection in reply to smdv806, 12-04-2007 17:10:09
10psi of boost is so low you can run without an intercooler. Go with a draw through system and a carb. As you get addicted to higher and higher boost. You can add water/alcohol injection if detonation occurs when using 100LL gasoline. Inject the water at the compressor discharge, not into the inlet.
ChadS
12-07-2007 06:53:11
The first thing you need to do, is decide on a multi port, or a throttle body EFI,,, next is to build a magnetic pick up, or crank trigger off the damper pulley. This feeds the computer that you use to tell it what and where the crankshaft position is to fire the TBI or injectors. Thats the most important part,,,,, or, you build a distributor that used EFI to act as the signal device. Ford 300 6 cyl with the late model module is best choice,, 6 cyl to 6 cyl,,, and the computers are easy to build harnesses for. Its too bad you dont want a V8 in the 560!! I have a complete EFI setup off a 302 that will work in anything! I thought of putting in a EFI 302 in a M or something,, with th engine out of a mustang or something,, but would be neat to see a EFI engine in an old tractor.. maybe add a turbo or two and tune it on a laptop computer,,,,, depending on the controller for the EFI,,, ChadS [email protected]
