453 detroit
Pullin Jimmy
11-20-2007 19:55:46
Can anybody tell me who or where I can get information on getting maximun horsepower out of a 453 detroit. Possible mods on head, blower, camshaft, injectors, upsizing sleeves and pistons? Thanks for any help
1206SWMO
11-22-2007 11:28:25
 Re: 453 detroit in reply to Pullin Jimmy, 11-20-2007 19:55:46
I assume that you want it to run like this one in KY.
L.D.W.
11-23-2007 14:13:55
 Re: 453 detroit in reply to 1206SWMO, 11-22-2007 11:28:25
Try this link for a couple detroits! :) From up here in WI. Link
Pullin Jimmy
11-24-2007 16:15:13
 Re: 453 detroit in reply to L.D.W., 11-23-2007 14:13:55
I can't seem to get the link to work. If you have any contact info on the pullers I would appreiate it!
Pullin Jimmy
11-22-2007 20:37:14
Yes, you assume correctly. Do you know who this puller is or where he pulls?
1206SWMO
11-23-2007 20:00:01
 Re: 453 detroit in reply to Pullin Jimmy, 11-22-2007 20:37:14
Its Dallas Roberts from somewhere in KY.His Dad is Steve Roberts.They are on here from time to time.
Pullin Jimmy
11-24-2007 06:54:38
 Re: 453 detroit in reply to 1206SWMO, 11-23-2007 20:00:01
Thanks for the information !
local puller
11-21-2007 03:46:52
How much hp are you needing, are rules to your application limiting you rpm etc,
Pullin Jimmy
11-21-2007 07:57:17
 Re: 453 detroit in reply to local puller, 11-21-2007 03:46:52
I am limited to 3000 RPM in most classes. I have been told that some military and marine applications make up to 250 HP. I would like to attempt to make as much HP as possible without a turbo? Some have suggested running a blower on both sides of engine? Thanks for any help!
guido
11-21-2007 12:41:09
 Re: 453 detroit in reply to Pullin Jimmy, 11-21-2007 07:57:17
Hey pulling JIM
Looks like you got a screamer lots of rpm's on that engine.If you turbocharge the engine it will produce the max H.P about 10% sooner in the R.P.M. range about 35 more h.p.stock . Never seen blowers on both sides, how do the get hoocked up? The h.p. on this engine are at the max R.P.M. If you can keep the engine droop to a minimum that will help also.
Guido.
Pullin Jimmy
11-24-2007 07:05:09
 Re: 453 detroit in reply to guido, 11-21-2007 12:41:09
I would like to turbo this engine, but I can't run a turbo in most of the classes I compete in. Thanks for the response
local puller
11-21-2007 11:26:02
e-mail your phone # and I will call you [email protected]
Pullin Jimmy
11-24-2007 07:00:10
 Re: 453 detroit in reply to local puller, 11-21-2007 11:26:02
Thanks for the call, I appreciate the help
