Oliver 1655 overhaul kit will it fit.
Tim
06-03-2002 05:55:41
Will a 1655 over haul sleves and pistons fit in a super 88 block with 3 3/4 pistons already in it. I want to know because I'm told a 1655 kit has 3 7/8 pistons in it and in my diesel I can't get the 3 7/8 pistons.
Seamo
06-03-2002 20:32:23
 Re: Oliver 1655 overhaul kit will it fit. in reply to Tim, 06-03-2002 05:55:41
Tim, Are you wanting 3.875 bore in your super88 diesel ? You could bore your 88 sleeves to 3.875.I have bored the 88 gas sleeves to 4.00 by customer request. He didn't have any trouble. The question is will they take diesel comp ratio? I looked in my old M&W book they went to 3.875 on gas but not on diesel. Didn't they have a little crank breaking problem on the diesel? Looking in my spec book you might be able to use the 2524p Sealed Power piston out of 1800 diesel. My book shows that piston to be 3.875 bore 2.375 comp distance 1.250 pin. flat top .You would have to machine .0625 offtop to fit 88 diesel. Will this help? Earl
