v8 tractor
JDPuller
11-16-2007 15:20:58
Has anyone put a v8 in a early model two cylinder frame John Deere?
Jim in OH
11-19-2007 05:44:05
 Re: v8 tractor in reply to CGpuller, 11-16-2007 15:20:58
JDPuller said: (quoted from post at 16:20:58 11/16/07) Has anyone put a v8 in a early model two cylinder frame John Deere?
Here is the one at johnnypopper.com....third party image
of puller
11-18-2007 15:27:13
 Re: v8 tractor in reply to JDPuller, 11-16-2007 15:20:58
odon machine and manufacturing is the machine shop that does these conversions has done multiple jd's and a wd45 that I know for sure he has also converted a 2cyl from gas to diesel
BushogPapa
11-16-2007 17:44:22
There is one around here..a JD 60 with a 350 V-8 Diesel in it.. Still uses the hand clutch as if it was original equipment..!! The kit was made/installed in Oden, Indiana..it even has a serial tag made and installed by them.. If it can be done in a 60, it can be done in the Unstyled ones too..
JDPuller
11-16-2007 18:36:33
 Re: v8 tractor in reply to BushogPapa, 11-16-2007 17:44:22
Well could you maybe send me some pictures and tell me how it was done. Thanks
BushogPapa
11-18-2007 10:09:12
 Re: v8 tractor in reply to JDPuller, 11-16-2007 18:36:33
I am not sure where my pictures of it are..maybe I can find one..
The motor is mounted in the frame in the usual manor, only one notch on the left side for the oil filter unit.. Looks like a 3/8" adaptor plate between engine and JD crankcase.. New shaft has to be machined to fit the original clutch side parts, and a ring and pinion installed on that shaft, engaged in the v-8 engine...no clutch is used there, only the original JD clutch... It was at "Calvins Fall Harvest Festival", this year, but I don't think they plowed with it.. The Owner died not long ago, and the family still like to bring it and run it in parades.. They would certainly have pictures..if you can contact anyone at Calvins.. The Antique tractor club in Delaware, Ohio is probably where they belong, as members...
Ron.
MN Dave 2
11-16-2007 17:41:07
I "wasted" big block mopar (mopar people were mad) on just a common farmall M (IH people were insulted that I wasted a M). You would need a medic on standby for all of the JD 2-cyl fan(atics) stroking out.
Drew
11-16-2007 18:57:59
 Re: v8 tractor in reply to MN Dave 2, 11-16-2007 17:41:07
Thats all the more reason to do it....just to pi$$ the correct police off.
4020LP
11-20-2007 01:22:30
 Re: v8 tractor in reply to Drew, 11-16-2007 18:57:59
If you're childish enough to spend a bunch of money just to tick off some people you think it might bother, you're as dumb as those people say you are. They're not mad---just laughing at you for pouring money down a rathole, because in the end, that's all you've done.
oklahoma jd scraper
11-22-2007 12:18:51
 Re: v8 tractor in reply to 4020LP, 11-20-2007 01:22:30
I agree. Why waste money and a V-8 on a jd, they are only worth so much for scrap either way and worthless running.
4020LP
11-20-2007 01:22:30
