leaking john deere a
lowrideer
11-13-2007 19:15:52
need suggestions on which gaskets to use (john deere or aftermarket). i restored tractor ground up in 99 using all john deere gaskets, head was shaved, checked the deck with straight edge and checked fine. have coolant leak between head and block and oil leak between block and case while under load. in process of tearing down, rechecking and shaving if nec. head and block (deck and back side). also going to replace studs (block to case) and head studs and nuts. any suggestions would be appreciated.
ES
11-14-2007 16:26:46
 Re: leaking john deere a in reply to lowrideer, 11-13-2007 19:15:52
Make sure you use lead washers on the headstuds between the head and the nuts to get the right torque
toot
11-14-2007 09:16:34
block to case you can use a little permatex or related product, head gaskets had same prob on some...I have used some sealants on those also...make sure you start in the center, work your way out on tightening, also to correct torque values
MJF
11-13-2007 20:40:39
we've been happier with the felpro compared to Quality JD and at a portion of the cost
730-LP
11-13-2007 19:37:47
I have had good luck with the after market. I'm not in the shop but I think they are fel-pro.head gasket,valve cover,manifold and stud washers around 1/2 what a Deere head gasket cost.I have one on an A with a power block running 1/3 more compression than a standard A with no problems.Did you retorque your head after a few warm ups?
lowrideer
11-14-2007 05:40:13
 Re: leaking john deere a in reply to 730-LP, 11-13-2007 19:37:47
yes i did retorque, what about block to case, like i had said i will check flatness of deck, back side of block, case and will correct if necessary. also thanks for your input
Life of Riley
11-13-2007 19:57:24
730-LP is right, check the torque on the head. I"ve had some start leaking but after a re-torque all was well. You might be surprised how much the nuts actually turn. A stock head gasket will usually handle double the factory compression with no problem, they"re actually pretty good gaskets.
