adding cubic inches to a 4020 gas
gcm
11-11-2007 18:24:55
How big can a 362 gas be built and still be reliable? bore and stroke?
thanks in advance
smdv806
11-13-2007 17:18:18
 Re: adding cubic inches to a 4020 gas in reply to gcm, 11-11-2007 18:24:55
Get a diesel 466 and convert it to gas. Use a crank sensor for your ignition and run alky in it!
765 EASY
11-13-2007 11:10:45
5x6.5
alby15
11-14-2007 18:15:41
 Re: adding cubic inches to a 4020 gas in reply to 765 EASY, 11-13-2007 11:10:45
how doyou get a 5 inch bore or sleeve in a 466?
what size are H journals?
alby15
11-13-2007 14:53:38
have you done this? if so how did you make room?
YES
11-14-2007 11:07:14
 Re: adding cubic inches to a 4020 gas in reply to alby15, 11-13-2007 14:53:38
5x6 H Farmall rods, no clearancing required, aircraft pistons, cheap bolt together deal
EFV
11-12-2007 04:19:00
Why not use a diesel block ? more cubes,more bearings .
