OT cummins help
pieceofjunk
11-09-2007 05:59:31
I have a 93 Dodge 250 with a 12 valve cummins. I replaced an injector and now it will not start. I have tried to bleed it out numerous times, but it seems like it isnt getting much if any fuel through the injection lines. If I unhook all the lines from the injectors and crank it over I only see maybe a drop of fuel come out every once in a while. Do I still have air somewhere? What things should I check for?
guido
11-09-2007 09:26:56
 Re: OT cummins help in reply to pieceofjunk, 11-09-2007 05:59:31
Hey pieceofjunk. It sounds like you have no fuel in your filters.
Make sure the are full and the pump will pick up the fuel. You should crack open all the lines now they all need to be blead.
If you have an electric valve that turns the engine on and off make sure it has power to it. if it is mechanical the fuel stop is not pulled in the engine off position. GUIDO.
Jim Troaka
11-09-2007 07:01:30
I have a IHC tractor with a diesel in it an i had this problum,my pump is a little weak,my filter was a little plnged,and my tank was a little low on fuel,i filled the tank with fuel and thing workes
Jim F.
11-09-2007 07:45:10
 Re: OT cummins help in reply to Jim Troaka, 11-09-2007 07:01:30
Here is a link to a good Dodge Cummins forum. Browse through or join and post your problem in the appropriate catagory and you get some help!!!
Link
Good luck.
