Question from a non-puller
ebbsspeed
11-07-2007 12:36:36
I occasionally watch the pulls on RFDTV, and have a question about the big turbocharged diesels, I think they're probably called "superstock" or something like that. I've noticed that some of these tractors idle nice and smooth, while others in the same class will have a really bad surge at idle, with an accompanying blast of exhaust, almost as if their is some kind of wastegate popping off. What causes this?
james rumph
11-07-2007 18:51:26
 Re: Question from a non-puller in reply to ebbsspeed, 11-07-2007 12:36:36
It is the cam shaft grind [ overlap ] meaning that booth valves intake and exhaust are open at the same time . [ very short time ] As rpms get higher the rpms come in nice and smooth.
These cams are ground for turbo motors .
