Farmall M, Degree Wheel?
Degree Cam
11-05-2007 19:01:47
I need to degree the cam in my Farmall M, but hoe do i put a degree wheel on the crank. I need to order one and don't wanna spend a lot of money. Thanks Guys
High Octane
11-14-2007 09:07:42
 Re: Farmall M, Degree Wheel? in reply to Degree Cam, 11-05-2007 19:01:47
Mshultz,,, when you say the M was right on, and you had to make a key for the H,,,,,
Was the cams' stock and you guys were dialing in a stock cam, or were they regrinds? What made the H so far out of whack to need the key to be offset? Normal wear and tear on the gears and the keyways? Or are they really that far off from the start? How did it help after you degreed the camshaft?
MJF
11-06-2007 18:32:48
Well I believe I'm going to make a TDC stop. Back to the degree wheel My crank has the end for the crank starter
mshultz
11-07-2007 04:32:52
 Re: Farmall M, Degree Wheel? in reply to MJF, 11-06-2007 18:32:48
the end of the crank is center drilled. If I remember right, we drilled it about 3/4" and put 1/4" threads in it and attached the degree wheel directly to the end of the crank. We could probably loan you the wheel if you need it.
Thanks Mike
11-07-2007 12:24:18
 Re: Farmall M, Degree Wheel? in reply to mshultz, 11-07-2007 04:32:52
Thanks for the idea I'll prolly try that. I believe I'm just going buy one my self, I figured I'm young and in my life I'll probably need one. Right now I'm just playing around with it trying to see if i can find a little more power. Then I'll have everthing I need if I ever build what I want, well except the money. Thanks again for the help and the offer
mshultz
11-08-2007 10:05:34
 Re: Farmall M, Degree Wheel? in reply to Thanks Mike, 11-07-2007 12:24:18
Be careful when tapping the hole. It really only takes a few threads to hold the degree wheel on - no need to overdo it. Good luck - I think it's well worth the effort.
MJF
11-09-2007 12:21:12
 Re: Farmall M, Degree Wheel? in reply to mshultz, 11-08-2007 10:05:34
did you guys ever check a stock cam to see how far it's off. And do u know who makes the offset keys if I need one . Thanks
mshultz
11-10-2007 18:56:20
 Re: Farmall M, Degree Wheel? in reply to MJF, 11-09-2007 12:21:12
The whole thing is different from one engine to another - some are right on, and some are off a little. My understanding is that when they were made they had a certain amount of tolerance for things (cams, gears, keyways, cranks, etc.) to be off a smidge and still operate under normal working conditions fine. But when trying to fine tune for max power we want to eliminate the tolerance for being off a little and make it as perfect as possible - which is why you degree your cam in relation to your crank rotation. Tim Carr made a key for us for our H, and the M was okay. Good luck.
Greg_Ky
11-05-2007 19:56:46
The degree wheel will come with adapters for different size crank bolts, it bolts to the end of the crank. You will also need a 0"-1" dial indicator and adjustable magnetic base and a piece of wire for a pointer and the cam spec. card to degree your cam.
Greg_Ky
11-05-2007 20:05:22
 Re: Farmall M, Degree Wheel? in reply to Greg_Ky, 11-05-2007 19:56:46
I should have also added a positive piston stop to find top dead center.
