Resleeving U jugs
family traditio
11-04-2007 15:02:50
How big can a U moline jug be sleeved and hard blocked? Can they go to 5.5? Want to stay with short blocks and offset grind a 6" crank to U rod journal size. Anyone ever built a motor similar to this that can give me some insight? Thanks in advance.
Mopower
11-08-2007 19:21:32
 Re: Resleeving U jugs in reply to family tradition, 11-04-2007 15:02:50
5.75" from Henderson power. I've seen a set run for years with literally hundreds of hooks. Never any problems. Always winning too. They run water through them. He also stands by his work. Good fella.
Dieselbear
11-05-2007 19:59:01
I make solid jugs in both alum. and in cast. They don't leak, and with a press in sleeve can be repaired. Have done them 5.75 and I think there is room to go to 6
AC
11-06-2007 05:56:20
 Re: Resleeving U jugs in reply to Dieselbear, 11-05-2007 19:59:01
What do you charge for a cast aluminim set? ..AC
Dieselbear
11-06-2007 08:48:54
 Re: Resleeving U jugs in reply to AC, 11-06-2007 05:56:20
The short blocks, raw castings, are 400 each. Send me an email and i'll send you some pics. if you want
Thanks, Glenn
complete
11-06-2007 13:59:06
 Re: Resleeving U jugs in reply to Dieselbear, 11-06-2007 08:48:54
Hey, how much for something ready to bolt in?
Dieselbear
11-07-2007 14:54:36
 Re: Resleeving U jugs in reply to complete, 11-06-2007 13:59:06
Don't sell them finished any more, machine shop was taking forever
AC
11-05-2007 04:18:17
Just call Doug Henderson. 5.75" and it wont leak.
1 269 929 4216.
UB MM
11-05-2007 04:41:28
 Re: Resleeving U jugs in reply to AC, 11-05-2007 04:18:17
You might want to check with some pullers that are running "5.75" and it wont leak" blocks. The ones I've talked to are having some water leaking problems.
LW
11-07-2007 17:17:59
 Re: Resleeving U jugs in reply to UB MM, 11-05-2007 04:41:28
No water in the oil here!
AC
11-05-2007 05:00:35
Some times you have to follow directions, too. Most people think they know better, and then stuff happens.
UB MM
11-05-2007 09:24:47
 Re: Resleeving U jugs in reply to AC, 11-05-2007 05:00:35
Ha HA, that's funny. Blame it on the person that has the leak and not the person that made it.
AC
11-05-2007 10:58:20
 Re: Resleeving U jugs in reply to UB MM, 11-05-2007 09:24:47
Just because you cant seal something does not mean it cant be done. Your attitude is starting to remind me of a person that completely ruins something out of stupidity, and then gets mad and pitched a fit when it can't be warrentied.
