jd a puller
chris jackman
11-02-2007 15:31:28
Just wonder what i caould do to a stock 48 a. I am not going for the ground pounder thing or nothing,just the small little hop ups peaople can do.Dont want to get into any heavy engine work,is there any simple mods i can do?
3dollarTrophy
11-07-2007 07:54:05
 Re: jd a puller in reply to chris jackman, 11-02-2007 15:31:28
#1:Hard old tires, #2:max hitch height, #3:well tuned carb, #4:clear air and fuel flow.... in that order.... on a well balanced high gear "STOCK JD A" ....will win lots of Div.1 pulls from 5100 to 7100lbs.
I prove it every weekend in large ten entry classes!
Hoss in Maine
11-05-2007 16:40:27
..... ..... 25 in steel plates??!@#$@? are you #%&@!ing nuts? Running for cover,,Hoss
sparkplug
11-05-2007 18:05:28
 Re: jd a puller in reply to Hoss in Maine, 11-05-2007 16:40:27
lol!! thats what i told him! it does run real well and is one of the best pullers around, so he must have done it right!! (i wouldn't try this at home, kids.)
johndeereman
11-04-2007 15:18:18
im not sure which way my dad did one by mistake when he was 16 he said he forgot to compensate for the gears turning when he put them on said they put in on the blower (belt driven) and they could unload the wagons in high gear (haylage) that tractor pushed it up a 40 foot silo without even a grunt pulled a 3 bottom plow in 4th gear with it that way
MJF
11-04-2007 19:34:19
 Re: jd a puller in reply to johndeereman, 11-04-2007 15:18:18
I don't know what he was plowing but where I live it's clay, and it would take a real real strong A to pull 3 bottoms in 4th. A real strong A, no matter where the timing was
smdv806
11-04-2007 08:54:11
NOS!!!!! !
johndeereman
11-03-2007 18:10:58
set the timing marks for the crank and the cam one tooth off you cant stop it just dont run it too long it vaporizes the fuel it will turn the manifold white as a ghost
sparkplug
11-04-2007 05:44:01
 Re: jd a puller in reply to johndeereman, 11-03-2007 18:10:58
which way should he set it off? advanced? retarded?
this sounds like something i might try doing in the future.
Mike n Mo
11-04-2007 18:09:15
 Re: jd a puller in reply to sparkplug, 11-04-2007 05:44:01
If you were to change the cam timing you would advance the cam. That is quite a bit of an advance for a stock cam, though. Mike
sparkplug
11-04-2007 18:44:40
 Re: jd a puller in reply to Mike n Mo, 11-04-2007 18:09:15
yeah thats what i was thinking. my friend has an A, and he bolted .25 inch steel plates on the pistons. i asked him how that worked and he said-USE LOCTITE!!!!! !!!!
