NEED HELP ON OLIVER77 OR 70
ERIC60I
10-31-2007 18:16:29
HAD FINAL PULL FOR THE SEASON. INPROVED A LITTLE WITH NEW TIRES,NEW CARB. BUT CAN NOT KEEP UP WITH THE BUILT ENGINS IN THE ANTIQUE CLASS. WHAT CAN I DO TO COMPET WIT THEM NEXT SEASON? THANKS ERIC
High Octane
11-19-2007 15:56:15
 Re: NEED HELP ON OLIVER77 OR 70 in reply to ERIC60I, 10-31-2007 18:16:29
Maybe put 3-3/4 bore sleeves with 88 pistons in em. Should be the same compression height and pin diameter. I know of a piston at 3-3/4 bore to use with a small stroker,, but its never been tried to know what it would do.
Going to Blow
11-04-2007 03:21:09
Is your hitch up as high and as far in as the rules allow? Tires with 50% tread, age hardened and with a nice road worn front edge are a lot better in most cases than brand new tires. What tire size are you running and on what width rim? What is the biggest size of tires allowed in your class at the weights you run? Is your front end coming upa little towards the end of your pulls? Are you spinning out or powering out at the end of the pull? How much farther do the hotter tractors pull? Have you dyno tuned your tractor? Is the compressionclose to equal between cylinders? How much time do you spend studying the track for low and high spots, wet areas, etc.?
ole77
11-01-2007 16:08:56
bild yours
ERIC60I
11-01-2007 16:36:32
 Re: NEED HELP ON OLIVER77 OR 70 in reply to ole77, 11-01-2007 16:08:56
YOU SAY BUILD IT. WHERE DO YOU START. HEAD PISTONS, CARB. OR TOTAL?
11-01-2007 08:50:25
What are your rules and weight class ????
ERIC60I
11-01-2007 09:18:18
 Re: NEED HELP ON OLIVER77 OR 70 in reply to ????, 11-01-2007 08:50:25
I LIKE 4000LB. TO 5500LB. RULES? SEEMS LIKE WHAT EVER YOU CAN GET AWAY WITH. 3 MPH IN ANTIQUE.NO CUT TIRES. I GET BEAT BY TRACTORS THAT CAN PULL IN THE MODIFIED ANTIQUE, THEY JUST SLOW DOWN THE TRACTOR.DO YOU JUST SEE WHAT YOU CAN GET AWAY WITH?
11-01-2007 12:36:10
 Re: NEED HELP ON OLIVER77 OR 70 in reply to ERIC60I, 11-01-2007 09:18:18
3 mph will take away some of there big HP then it comes to the tires and setup . Look at there tires new, half wore out , top cuts , road wore ? oliver 77 is a very good 4000 -4500 lb tractor with the right setup and tire for the track that you pull on.Track suface means a lot too loose on top ,sand , hard packed , wet,????
ERIC60I
11-01-2007 14:14:05
 Re: NEED HELP ON OLIVER77 OR 70 in reply to !!!!, 11-01-2007 12:36:10
WHERE DOES HORSPOWER COME IN TO PLAY?WOULD A BUILT MOTOR NOT HAVE THE ADVANTAGE EVEN AT 3 MPH.?DO YOU WANT TO SPIN OUT OR POWER OUT?DOES MOTOR RPM MATER THAT MUCH? IT JUST SEEMES TO ME THAT A TRACTOR RIGHT OUT OF THE FIELD SHOULD NOT HAVE TO PULL WITH A TRACTOR THAT HAS BEEN BUILT.
Idea?
11-01-2007 16:38:08
 Re: NEED HELP ON OLIVER77 OR 70 in reply to ERIC60I, 11-01-2007 14:14:05
Maybe you should take your tractor to an "out of the field" pull. You wouldn't take a Yugo to the dirt track on saturday nite & expect to compete with those guys would you? In my opinion if you want to pull tractors at a "tractor pull" then you better step up your game just like the rest of the guys do. Once you get into it & figure it out, WHAM! your hooked. Build a pulling tractor & have a helluva good time & enjoy yourself!
