is stroking worth expense
joecool
10-28-2007 07:48:45
is stroking worth expense, or isn't more economical to bore and be happy? any expert opinions?
b bareine
10-31-2007 16:07:39
 Re: is stroking worth expense in reply to joecool, 10-28-2007 07:48:45
It's entirely up to the division and classes, you want to pull !
I've had an M crank standing on end for two years, can't wait to mow grass for the last time this season !
crank goes in, (1)inch of stroke for a division (1) , first gear puller (farmall) !
It's absolutely worth it !
just my opinion !
Eddie Haskell
10-28-2007 18:03:22
Not always, been pulling a 281ci farmall for 8 years, botton line-depends on what classes you want to run and how deep your pockets are.
buickanddeere
10-28-2007 17:09:18
Strokers are vital so your tractor can be legal in the stock classes.
jd b puller
10-30-2007 05:53:02
 Re: is stroking worth expense in reply to buickanddeere, 10-28-2007 17:09:18
B&D, You need to bore it for your "stock" tractor as well, just make sure you use your "road sharpened" tires, so you can still pull "stock"
RWWisehart
10-28-2007 14:25:06
Yes it is, that is where you will get the power.
johndeereman
10-28-2007 13:38:56
if i was you id do some research theres been enough engines built that theres prob a crank out there that is the throw your looking for but hasnt been cut and welded
