which tire ?
kendak
10-27-2007 19:19:52
Need some help ..on a WD-45 what tire would be best ?? [14.9 X 28] or [18.4 X 26] tractor is stock except for D-17 manifold & carb....thanks ...Kent
just another puller
10-31-2007 11:13:20
 Re: which tire ? in reply to kendak, 10-27-2007 19:19:52
I love it .He answers your question with many other qustions and younever did get a solid answer.Pull as big a tire as rules allow and motor will turn.
Puller504
10-28-2007 03:01:33
I"ve pulled with both tire sizes, I need more information to help. What type of pulling? Concrete, dirt track? Horsepower? Transfer sled or dead weight? Gearing? Etc, Etc. Don
kendak
10-28-2007 15:43:37
 Re: which tire ? in reply to Puller504, 10-28-2007 03:01:33
dirt track...transfer sled ...1'st gear only...thanks Kent
Puller504
10-28-2007 17:04:37
 Re: which tire ? in reply to kendak, 10-28-2007 15:43:37
What is the weight limit of the class(es) you plan to pull in? Any other AC's in those classes? What size(s) of tires are they running? Do the rules have tire size limits? Horsepower limits? 14.9x28 tires are one size larger than stock and may be a factory option for the WD45. The 18.4x26 tires will need a very strong engine to spin them out. I started out small and worked my way up over the years. Sold my WD this summer and now pull ONLY my Oliver and my Farmall.
kendak
10-29-2007 05:55:31
 Re: which tire ? in reply to Puller504, 10-28-2007 17:04:37
Will pull in 35 to 4500 lb class...other WD's in this club use 16.9 X 38 or 15.5 X 38 some use 14.9 X 28...I have both the 14.9 X 28 & 18.4 X 26 ...think I'll try the 18.4 first...I'm used to running 730 D in 6500 & also have 820 will be pulling in 10000 class... thanks ...Kent
gpuller
10-31-2007 13:08:20
 Re: which tire ? in reply to kendak, 10-29-2007 05:55:31
kendak said: (quoted from post at 05:55:31 10/29/07) I'm used to running 730 D in 6500 & also have 820 will be pulling in 10000 class... thanks ...Kent
A 730D in 6500...how you doing that?
hahter
10-31-2007 14:14:54
 Re: which tire ? in reply to gpuller, 10-31-2007 13:08:20
The same as I pull a Jd 820 in the 7000 lb classes.
gpuller
10-31-2007 14:56:01
 Re: which tire ? in reply to hahter, 10-31-2007 14:14:54
hahter said: (quoted from post at 14:14:54 10/31/07) The same as I pull a Jd 820 in the 7000 lb classes.
How far is it stripped? Are you doing it with a pony start? I have a plan in mind to get an 820 to 6500. It's a someday project.
hahter
11-01-2007 16:45:52
 Re: which tire ? in reply to gpuller, 10-31-2007 14:56:01
GPuller, this is the one My father brought from Garry out of Texas. No pony, wheatland rearend cover, 18.4x38 on 9-bolt rims, custom driver's platform, and a custom fuel system. I think yu know the rest of the story of this tractor.
gpuller
11-02-2007 06:53:52
 Re: which tire ? in reply to hahter, 11-01-2007 16:45:52
hahter said: (quoted from post at 16:45:52 11/01/07) GPuller, this is the one My father brought from Garry out of Texas. No pony, wheatland rearend cover, 18.4x38 on 9-bolt rims, custom driver's platform, and a custom fuel system. I think yu know the rest of the story of this tractor.
Yep, I know the tractor. Thanks!
