Welding rods together
Mike S
05-30-2002 16:33:16
I have a arc welder and want to know what welding rod to use to make rods for my farmall H. I will have to use 8 rods to make 4. Also what is the best way to get them straight.
John
06-03-2002 05:34:17
 Re: Welding rods together in reply to Mike S, 05-30-2002 16:33:16
first, rods break easy, we had a set that did, and 2nd, u can have rods made. I'm sure it's pricy, but u know they will hold. 2nd, if they were made, u have to make sure it's right. If the price is right, and the guys that are welding them, they break, will he cover the damage, or will he just let it go. after all, he did the work:S
just my thought's
they can break
05-31-2002 08:38:40
I know of a moline that had merfield welded rods and they broke after1/2 a season and took the jug, crankcase and head to the scrap pile to now nobody get mad! I am just repeating facts I have nothing against the man.
Mike f.
05-31-2002 19:55:04
 Re: Re: Welding rods together in reply to they can break, 05-31-2002 08:38:40
Your right, anything can break, and maybe welded rods don't belong where they shouldn't be in the first place, hard to say what the underlying factors where, but way too much compression or detonation was probably the cause, two cents.
SEAMO
05-30-2002 21:50:41
You have to make a jig to do the rods right.That is if you want the center to center length to be exact. Merfeld does a good job on cranks. But his con rods are just butted together and weld. That is the ones I saw. To do the rods right they are butt weld and plated on the sides. The ones we have done have run for years no problem. They will take 10 to 11 to one compression plus over on RPM. E mail me I can walk you through the process.Earl
What is the Cost???
05-31-2002 05:09:31
 Re: Re: Welding rods together in reply to SEAMO, 05-30-2002 21:50:41
Tell us what the cost would be for 4 rods.
Seamo
05-31-2002 06:57:34
 Re: Re: Re: Welding rods together in reply to What is the Cost???, 05-31-2002 05:09:31
We can't discuss price on this forum. Call area code217-892-9696 ask for Pete Good at G&G machine Rantoul, Illinois He does very nice work. 9-4 central time.Earl
Yes we can!
05-31-2002 08:41:46
 Re: Re: Re: Re: Welding rods together in reply to Seamo, 05-31-2002 06:57:34
Tell us all what you charge to do someting like this. Give us an example of what you can do AND THE COST.
Will
05-30-2002 18:22:40
I WOULD ADVISE AGAINST WELDING RODS!!!!! !
DougS
05-31-2002 07:33:44
 Re: Re: Welding rods together in reply to Will, 05-30-2002 18:22:40
Merfeld did my rod's. They were laughed at by all the mechanical "expert's". But they work, and have ran now over 5yrs in hard lugging, hi rpm situations. I would do it again anytime on anything!
Mike F
05-30-2002 19:07:56
The ones I am running in my A were done by keith merfeld and are fine, I know he line bores them once done being welded, try him out.
