706 466
smdv806
10-22-2007 15:07:37
How much work is it to put a 466 in a 706? Can I use a 966 flywheel without having to use a a spacer or a making changes to the ring gear? Is the frame long enough?
ejr-IA.
10-22-2007 17:35:36
 Re: 706 466 in reply to smdv806, 10-22-2007 15:07:37
Im working to do the same.Have most of the parts to do the exchange.I'm going to use the narrow frame rails instead of the 66 rails either will work but the 66 rails would be easier, I want the 06 look.I'm useing 806 rails which I will have to strech some.For the hood I will use a 560 hood because their longer will cut to fit.The motor plates front and rear are from a 1066 and also the flywheel.You will have to make a cross over lower radiator pipe if you use the orignal rad.Then theirs a few more smaller details you can work out.
