M vs. Super M block
Charles E. McNe
10-21-2007 08:58:17
Other then the bore, what differances are there? Question #2. Is the factory cam in the Super M the same as the 450 cam? I think no.
Thanks,
Charles
MJF
10-22-2007 17:27:48
 Re: M vs. Super M block in reply to Charles E. McNelly III, 10-21-2007 08:58:17
Not sure on the numbers but one had left hand threads and the other was right hand threads. They changed the thread direction due to the live pumps. Hope this helps
D Slater
10-22-2007 16:30:31
Late M block not a whole lot different from SM other than bore castings. 2 different cam numbers were used in a 450 and the original SM cam was not the same as either.
10-22-2007 16:46:05
 Re: M vs. Super M block in reply to D Slater, 10-22-2007 16:30:31
Thanks, any chance that you would have the cam numbers? I'm pulling apart a super M with a replacement 281 block and I'm curious which cam it is. I have a W-6 with the 248 engine in it and if the cam would be better, I'd change it out. Thanks,
Charles
D Slater
10-22-2007 18:06:42
 Re: M vs. Super M block in reply to Charles E. McNelly III, 10-22-2007 16:46:05
If you can find a IH # on the camshaft they will have # 45955. If it ends with D it came in M or SM, if ends with DA 400 and some 450, if DB later 450 and this uses left hand threads for gear retaining nut. Be warned that cams were replaced over the years so any engine may have any of the different cams installed along with aftermarket cams and some of those have left hand threads.
