pistons for c-301
steve still
10-17-2007 14:24:07
anyone have or know where to get a set of .060 pistons for a c-301 going to build one this winter am going to use stock rods
superm
10-17-2007 16:25:40
 Re: pistons for c-301 in reply to steve still, 10-17-2007 14:24:07
I have a set of 301 +.040 Hi Alitude I-H pistons for sale (used)
superm
10-20-2007 14:54:00
 Re: pistons for c-301 in reply to superm, 10-17-2007 16:25:40
I will be glad to get you a price in a few days. I am a little busy farming right now.
If you like I will call you.
steve still
10-22-2007 16:24:59
 Re: pistons for c-301 in reply to superm, 10-20-2007 14:54:00
if you want to give me a call the # 901-828-6589 I still need a set of pistons for a 301
High Octane
10-22-2007 19:58:51
 Re: pistons for c-301 in reply to steve still, 10-22-2007 16:24:59
steve still said: (quoted from post at 16:24:59 10/22/07) if you want to give me a call the # 901-828-6589 I still need a set of pistons for a 301
New ones are expencive!! Hint,,,, The C-200 gas 4 cyl Ih engine, uses the same piston as the 301. Same overbore options, dont know if high compression options are available or not. Anyways,, might buy 2 kits of the C-200 kits, have 8 pistons and maybe,, up to 100 bucks cheaper, and have 2 extras.
GSR
10-19-2007 18:32:29
What are you asking for the pistons and what kind of shape are they in? Thanks Greg
steve still
10-17-2007 17:16:13
I was realy wanting .060 over dome tops if I can find them
High Octane
10-18-2007 18:06:45
 Re: pistons for c-301 in reply to steve still, 10-17-2007 17:16:13
Napa can get the stock firecrater up to .060 over. A higher compression piston would be a flat top piston. Check out Ross Pistons they have them from std bore up to bigger bore sizes. Maybe a truck engine piston would do fine,,,,, Most of em were flat tops.
steve still
10-19-2007 11:48:11
 Re: pistons for c-301 in reply to High Octane, 10-18-2007 18:06:45
hey thanks for the info
