V-8 in a antique tractor
semoH
10-15-2007 21:19:38
I want to put a 350 small block in a antique tractor which one would be the best, less work i should say, AC WD 45, Farmall H or what. I think the NATPA has a class for this which ones work the best.
Ian Johnsen
10-16-2007 19:19:08
 Re: V-8 in a antique tractor in reply to semoH, 10-15-2007 21:19:38
I have built two Massey Harris V-8 tractors. The easiest would be a 44 row crop. The frame is longer than the standard. A small block Chev and a 4 speed trans fits no problem. The fact that these tractors had divorced clutch housings with either chain or bolt together couplers, allows you to mate about anything to the transmission input shaft. You will need an electric fan and a mini starter. Good luck!
54 MTA
10-16-2007 08:00:21
Sorry, the NATPA doesn't have a class for V-8 pullers. You can check their rules out at NATPA.com
buickanddeere
10-16-2007 00:58:08
Yep she's stock, came that way from the factory..... ..... ...
LWD
10-15-2007 22:50:49
`AC` WC you can slip in motor and trans to gether, have seen several with 292 gmc.with truck 5speeds the v8 would be simpler.
