Farmall M Diesel
JSB
10-15-2007 07:27:31
I have a 48 stock MD. It pulls fairly well in the 6&7K classes. The tractor runs good, but I am considering have my injection pump and injectors gone through.
Any suggestions, or is it a waste of money?
Thanks
JSB
10-15-2007 18:51:49
 Re: Farmall M Diesel in reply to JSB, 10-15-2007 07:27:31
I usually out pull the stock M, I was wondering if anyone had any personal experience with the IH gas start diesel injection system.
Thanks
ncdiesel48
10-16-2007 12:56:39
 Re: Farmall M Diesel in reply to JSB, 10-15-2007 18:51:49
Yeah I told you what you can do anything more you are going to spend a butt load of money to do it!
ncdiesel48
10-15-2007 13:34:35
Actually the 9 pump and the MD pump are different. The 9 has a bigger plunger and can deliver more fuel.....way to much if you don't get it set right. Go to the pictures and type in MD pulling tractor I have a few picks of how it should smoke when it is pulling.....
ncdiesel48
10-15-2007 13:37:28
 Re: Farmall M Diesel in reply to ncdiesel48, 10-15-2007 13:34:35
I will agree with the post below it is ALOT cheaper to get a gasser to pull. Now if you could get away with putting a turbo on it then you will have something. Our WD-9 will hang with any gasser as long as you can get it to hook.
n9lhm
10-15-2007 12:28:21
It depends. Is the torque control turned up in the pump enough that you get smoke when fully loaded? If so then there"s probably not much you are going to gain. IIRC it is the same pump that is used on the 9 series engines as the 6s, so if it has enough fuel for a 9 then it oughta make a 6 smoke pretty good.
I pull my MD, and enjoy it, but the problem is when you pull in a percentage pull, the extra weight of the diesel engine (400 lbs.) counts against you -- and the weight isn"t in the back where you need it. I pull well but don"t always score well.
Craig-NC
10-15-2007 11:56:39
Personal experiences tell me a Farmall M gas would beat a diesel anyday, so i would just get a gas, but your desision.
