tractor pull left or right
local puller
10-12-2007 10:28:51
Have had a problem for several years,my pullin tractor always goes left or right as soon as the front wheels lift . I have decided its ovious that it acts like diff lock, is spider gears not running free
papuller
10-13-2007 14:12:31
 Re: tractor pull left or right in reply to local puller, 10-12-2007 10:28:51
Sounds like you need needle bearings in your differential.
local puller
10-14-2007 12:03:32
 Re: tractor pull left or right in reply to papuller, 10-13-2007 14:12:31
Yes this is what I am thinking,these needle brg, do they replace the thrust washers on the axle gears.or go else where
the real roger
10-13-2007 08:15:27
put more weight on the front to keep it down so you can steer
Redrules
10-12-2007 19:45:39
If it's consistantly one side, it could be a bad bearing or a brake dragging. If it's either side it might be in the spider gears. Have you jacked it up and spun the tires?
the real roger
10-12-2007 10:30:12
drawbar is not in the center of the tractor
local puller
10-12-2007 14:31:53
 Re: tractor pull left or right in reply to the real roger, 10-12-2007 10:30:12
No ,the drawbar is in the center,I have tried several sets of tires, raised and lower tire pressure, still the same
Jeff Oliver
10-12-2007 16:46:49
 Re: tractor pull left or right in reply to local puller, 10-12-2007 14:31:53
Check and make sure the rims are matched. Mine are a litle off which makes one ire just a little taller than the other. Also make sure the hubs are the same distance from the tractor. It does"t take much to throw the center off. Hitch needs to be in the center of the tires as well.
Unless your having trouble with one wheel pulling and the other not then your spider gears are probably not the problem. Now if your digging in one one side and not the other then I would check them
local puller
10-12-2007 17:42:31
 Re: tractor pull left or right in reply to Jeff Oliver, 10-12-2007 16:46:49
I have tryed several different sets of tires ,mounted, so I know its not tires, wheel, rims ,or distances. If you ever driven a regular farm tractor with factor diff lock, that what it acts like , wants it gets a mind of its own ,and changes directions,steering, brakes ,etc, you cannot change it back to go straight
the real roger
10-13-2007 08:14:51
 Re: tractor pull left or right in reply to local puller, 10-12-2007 17:42:31
LWD
10-12-2007 21:26:19
Just like drag racing, space the rear end as narrow as possible. the wide stance gives the tire more leverage to push the front to one side or other,,try it
hey goofy
10-14-2007 07:43:05
 Re: tractor pull left or right in reply to LWD, 10-12-2007 21:26:19
you have NO IDEA what you are talking about! Build something other than the stock stuff you put together and test it ve real horsepower tractors! I laugh every time you post something Mr DWL HAHAHAHHAHA
Ray Kiefer
10-14-2007 12:08:58
 Re: tractor pull left or right in reply to hey goofy, 10-14-2007 07:43:05
You have no idea who you are talking to. My nane is Ray Kiefer from missouri and I am going to pat myself on the back , I sure dont know everything ,but I am a little bit better than the average mechanic 573-547-1965. cell 573-517-3739
gfs
10-14-2007 06:04:45
You said you have changed air pressure, but have you staggered the air. Drop one side by a .5 pound to a pound and see if it helps. My second MM had to have 1.5 lb in the left more than the right to go straight.
