ANYONE ever go 6.5 stroke in a D17 block?
AC
10-08-2007 06:34:38
If so, what where the main problems (other than grinding) encountered, and what rod journal size did you use? Anyone have pics of a modified oil pan? ...thanks..
CrazyAllis Kurt Hamel
10-14-2007 12:39:54
 Re: ANYONE ever go 6.5 stroke in a D17 block? in reply to AC, 10-08-2007 06:34:38
6.5 will clear with custom rods and 2.000 pins,but your getting thin on crank strength.The other problem is that in keeping the comp ratio and the rod length within a realistic range is that it becomes difficult to get the wrist pin high enough in the piston to keep from pulling it into the area of the sleeve not supported by the block at BDC.Also if you make large displacement you have to be able to feed it.Take into consideration the cyl head,manifold, and carb combo it will take to feed it.If the combination is not both strong and effecient it will be an expensive experience. Kurt Hamel
mlpankey
10-08-2007 17:43:58
6 1/4 and youre running on weld in the rod journals with 1 3/4 rod jornal. mains are not any promblem but clearing the cam and oil rail is a real challenge especially the cam.
Oil rail
10-09-2007 17:36:00
 Re: ANYONE ever go 6.5 stroke in a D17 block? in reply to mlpankey, 10-08-2007 17:43:58
What is an oil rail? do you mean oil pan rail?
mlpankey
10-09-2007 18:04:12
 Re: ANYONE ever go 6.5 stroke in a D17 block? in reply to Oil rail, 10-09-2007 17:36:00
yeap theres all kinds of post under my name answering all kinds of questions on building stroker 226 engines . researching archives keeps double questioning down.
AC
10-08-2007 18:42:22
With what kind of rod?
mlpankey
10-08-2007 18:45:32
 Re: ANYONE ever go 6.5 stroke in a D17 block? in reply to AC, 10-08-2007 18:42:22
farmall c
Time Bomb
10-10-2007 11:02:51
 Re: ANYONE ever go 6.5 stroke in a D17 block? in reply to mlpankey, 10-08-2007 18:45:32
Putting Farmall C rods in a WC with a 6.5" stroke! Good Luck and bring a pushbar, so that you can get it loaded when it sends one of those through the side of the block!
R.C.
10-08-2007 14:28:46
You might try keeping the smaller one in one piece!
AC
10-08-2007 14:57:01
 Re: ANYONE ever go 6.5 stroke in a D17 block? in reply to R.C., 10-08-2007 14:28:46
