TIRES
devin m puller
10-07-2007 11:37:07
I am pulling a div.2 farmall M i have 15.5 tires and i am runing out of power i was wondering if i would do beter if i had smaller tires. or what can i do to my tractor and still pull div. 2.
pulls an M too
10-08-2007 10:54:50
 Re: TIRES in reply to devin m puller, 10-07-2007 11:37:07
Much as I love them a stock M will run out of power if you really get them hooked up.Firecrater pistons or m and w if you can find any and a 400 head will help you a lot and not cost toomuch.This is also the minimum mods on a good track you can still run her out,Same goes for other brands too.
devin m puller
10-07-2007 15:20:38
yea i have had it on a dyno. I am pulling 5000,5500,6000,6500
2 Cylinder
10-07-2007 14:20:47
Have you tried putting your tractor on a Dyno to see if your Fuel and Timing Adjustments are giving you the most horsepower you can get? If you haven't, I would start there.
stonerock
10-07-2007 13:29:34
what weight classes are you pullin
