Hillside KY using a dyno???
The Old Man
10-05-2007 00:48:17
What is this rumor I hear that Jeff is using a PTO dyno to check tractors with before they can pull at his place? If it is true, what is that supposed to accomplish anyway? What about tractors that do not have a PTO? Many were built that way . . . I know of several that pull against me often at several different places. I've even seen some that never had the PTO opening drilled from the factory, it was still as cast from the foundry with the knock-out plugs in place. Will those guys be left out in the cold or is there a provision to accommodate them so they can still pull?
jeffrey hale
10-17-2007 18:36:19
 Re: Hillside KY using a dyno??? in reply to The Old Man, 10-05-2007 00:48:17
this comment is for the old man its a shame people like you get on here and put stuff that you dont have a clue what you are talking about. do you know the differents between farm stock and super farm at hillside farms. where have ever seen wd-45 was allowed to pull in a class lower than a h=farmall. i have never had such rules before. what a dumb remark you made that you could gain 100% more horse power just by tuning one up. i did not go to a smaller tire size rule to put Jim Brumfield out. Jim put his self out by having a modified draw bar and limited slip rear end that not farm stock but he could have pulled super farm. i also do not require wheelie bars on farm stock just would like to know are you pulling in farm stock or super farm how many hooks are ya"ll having per pull in farm stock i average 118 hooks in farm stock alone limited to only three hooks i average 278 hooks in total hooks for each pull. as far a me and my brother Randy he had 18.4-38 cut tires and tried to pull in a class limited too 16.9-38 i did not tell him that could not pull he choose to unhook and load up RULES ARE MADE FOR ALL PULLERS INCLUDING FAMILY!! back to the dino deal i have never check a tractor before he pulls the oct pull i checked 12 farm stock tractors that had been winning alot all year only one checked bad that was a g john deere the book gives 38hp i woulod allow it to have 44hp but it had 55 hp thats not close to stock. HEY I GOT A GOOD THOUGHT GIVE YOUR NAME AND ADDRESS AND I"LL MAIL YOU A COPY OF THE RULES AND THEN YOU CAN READ THEM BEFORE YOU GO PUTTING STUFF ON THE WEB THAT YOUR NOT SO SURE ABOUT OR AT LEAST BE A "MAN" AND LET US KNOW WHO YOUR ARE TO FIND OUT YOUR PROBLEM, OH ONE MORE THING I forgot to mention that two of those tractor that i dino was mine the z moline that the book has 36 hp had only 35 hp and i also let someone eles dino and they did know what they was doing. i bet disqulified more family members and close friends this year than any other pullers anyone with any question please feel free to call me or e-mail me jeff hale 270-235-2099 or 270-348-4493. thank t" hancocks for taking up for our pull .
The Old Man
10-19-2007 22:49:17
 Re: Hillside KY using a dyno??? in reply to jeffrey hale, 10-17-2007 18:36:19
Jeff, it is a shame people like YOU get on here and go off half-cocked at people like me! I never down graded you for tossing your brother, I was pointing it out as a plus. As for the 100% more power, I never said I could do that against everyone, just that there could be that much variation depending upon what settings were used from one tractor to the next. I also never accused you of playing favorites with your family, that was 666, (see the above remark about your brother). AS for Birfield, he did NOT have a limited slip rearend, if you are still beating that dead horse, you have no business running a pull for pedal tractors, let alone real ones, his was ALL driver technique. And his drawbar was only modified to permit it to be easily adjusted up or down, as you can do on so many other brands of tractors, also he was pulling 13.6x38s and you had just changed two of your rules to not permit his drawbar and his tire size. Sure sounds like the rule change was aimed squarely at some certain person or people. And no, I don"t know your current rules because I left the day you tossed Jim and I"ve never been back, and won"t be back either. As for my "PROBLEM", the only one I have is that every time I hear of more brilliant solutions to non-existent problems, they almost always seem to have your hand in them somehow. It doesn"t matter if everyone pulled an A Farmall that made 500 PTO HP, since HP is NOT what gets you the win, but instead how well you harness that power to the ground. Driver technique wins more times than power does. One more thing, Jeff, you never answered my original questions. Also note that I asked about a "RUMOR" to begin with, I did not make any wild accusations against or about you. I also never mentioned "wheelie-bars" or anything else you accused me of, except I did pull that WD45 comment out of my a$$, but I do distinctly remember you having rules about what model pulled in what weight class.
If you can"t stand a little "heat" on the internet, get out of the business of being a target.
666
10-05-2007 20:18:49
he will do whatever it takes for his family and friends to win.
T. HANCOCK
10-05-2007 03:38:48
The dyno is used in farm stock only, as you and everyone else knows that pullers are going to push the rules as far as they can go. By having the the dyno there it allows out of field tractors a fair chance. I have never seen him require anyone to go to the dyno before they pull but if a couple wd allis pulls say 100ft. and runs out of power then one pulls 170ft. with plenty of power you can bet it's going to the dyno. I and many respect Jeff for going the extra mile to allow the true stock tractors a fair chance. Unless you are a farmstock not superfarm the dyno will not affect you at all unless you just wanted to hook to for fun, I'm sure he would be glad to do that for you.
The Old Man
10-06-2007 00:17:28
 Re: Hillside KY using a dyno??? in reply to T. HANCOCK, 10-05-2007 03:38:48
I"m sorry but I don"t see the connection with allowing out of field tractors a fair chance. My family"s tractors are all so stock they would stand a complete tear-down under anyone"s rules, yet we all win regularly, no matter where we pull. I"ve even seen Jeff Hale point to my own brother and tell everybody else in the class that he (my brother) was the one who ruined it for them!
Jeff even has those silly rules about what model tractors can pull in what weight classes as well, which I have always thought was ridiculous. What is "fair" about a WD45 with 225 cubic inches of motor being allowed in a lighter class than an H or a 350 Farmall with only 152 or 175 cubic inches of motor, respectively?
To me it sounds like sour grapes from people who don"t understand why their grandpa"s old wore out tractor that is still running on the rings and bearings that were installed at the factory won"t pull like one with fresh rings and bearings, and maybe new pistons and sleeves, and so forth. The simple truth is, the freshly built motor is always going to make more power than one with forty or fifty years of hard wear and tear on it, period. Either that or they don"t know how to tune an engine. There can be as much as 100% more power available in just the tune up settings you choose. You cannot just build it this year and run it the next ten years without ever turning another bolt and expect to win more than rarely, if ever! I dare say I almost must agree with 666 in his estimation of the issue.
If protecting the still working tractors is truly why he did it, why not just add a class called "Farm Stock Working Tractor", and not allow anything in it that even remotely looks like it did not plow the back forty last fall. No add-on weight bars, wheelie bars and such, all lifts, pumps, PTO"s and so forth must work and hydraulic systems must be full of oil and working. Sounds like a much more reasonable approach to me, and it doesn"t make anyone mad like back when Jeff went to his smaller tire rule in order to run Jim Burfield off, which he accomplished quite nicely I must say, as I was there that day when Jim left in a huff, and as far as I know, he has never been back.
Just to be fair however, I must say Jeff does try really hard, even to the point of one time I saw Jeff make his own brother angry by refusing to let him even hook to the sled since he obviously had tires that were to big for the class limit. If I remember correctly, he was trying to pull 14.9"s in a 13.6 class, but I am a little foggy on the memory. Must be a git"n old...
TOH
10-08-2007 18:42:50
 Re: Hillside KY using a dyno??? in reply to The Old Man, 10-06-2007 00:17:28
When was a wd45 allowed in a lighter class than a H farmall? Also,you can gain 100% more power with a tune up. Was the tire rule the reason Jim Burfield was asked to go to the next division or was it because of having a custom made hitch? I don't really understand why you would even go on here to start this crap. All you have to do if you have a question about the matter is just ask Jeff, trust me as many times as I've pissed him off he has always answered any questions or concerns that I had. TYLER HANCOCK
Jeff Oliver
10-07-2007 05:31:52
The problem is not in the sled operator but in the competitors. In the class you described there at some point would still be the guy whose only desire is to win so he would take his farm stock tractor and freshen the engine by shaving the heads adding bigger valves,changing the grind on the cam, drilling the jets on the carb, etc. And guess what? The PTO would still work, hydraulics would stil work,everything and it would still not be stock.
The one thing I really do like about Jeff is that as he told us one time in Paris, " I don't care how many times or if you go across the scales before you pull but your gonna go right after" I've seen lots of folks go across the scales early then start throwing weights on and never go back across.
Dyno'ing a tractor before a pull,ok. The way I see it if your legal what difference does it make? I jinda like the idea as I know several people who are running Open class tractors in Farm Stock. Of course according to the rules they are "legal" but they sure ain't stock.
On another note if you read this Jeff, I think the Paris club will be getting in touch with you next year, changed the show date to the end of Oct. so it might work better and be a heck of alot cooler!
The Old Man
10-07-2007 20:29:42
 Re: Hillside KY using a dyno??? in reply to Jeff Oliver, 10-07-2007 05:31:52
Dyno'ing the tractor is NOT a fair way to tell someone they cannot pull. If ten different people put together the exact same engine, then dyno it, you WILL get ten different readings! Some will be close, some will be higher, and one or two will be almost twice as much, IF the guy knows what he is doing.
Like I said originally, I'm TOTALLY legal, but I bet Jeff would toss me out if he puts mine on his dyno, just because I am that rare bird in these days of crate-motor horsepower, someone who KNOWS how to put an engine together to do what I want it to do, AND knows how to then tune it to keep it doing it.
As far as running an open class tractor in farm stock, ANY John Deere that pulls past half track in farm stock is one. (Here go all the JD lovers attacking me next!) ;o)
Just so you all know, my wife pulls JD's, and I have nothing against JD's. In fact, I prefer them!
Jeff Oliver
10-07-2007 20:43:59
 Re: Hillside KY using a dyno??? in reply to The Old Man, 10-07-2007 20:29:42
As I said, being stock and being legal are two completly different things. Heck I've got an A that will pull more than half track and it is legal. it even had a legal factory/dealer overbore as the engine has just been rebuilt last year. It's a little over what the original bore was but it is still stock. Never said yours wasn't just said there is alot of difference in stock and legal.
And yes a Dyno is a good thing. Never beel to a pull where they used one but I don't think that you have to hit the rated HP right on the nose. I'm pretty sure there is a range that you have to be within.
The Old Man
10-07-2007 22:46:55
 Re: Hillside KY using a dyno??? in reply to Jeff Oliver, 10-07-2007 20:43:59
I think I am having a little confusion in the terms you are using. By "stock" are you meaning "original as it came from the factory"?
Buckeye Oliver collector
10-10-2007 19:30:15
 Re: Hillside KY using a dyno??? in reply to The Old Man, 10-07-2007 22:46:55
Local club here uses a dyno on a lot of classes. Set hp limit on each class. A few examples: 5500 lbs. 55 hp, 7500 75 hp, 9000 90 hp etc. I rarely see guys get thrown out but it does happen. Only thing I don't like about the dyno is when I see 15,000 lbs. tractors dynoing before they pull and then right after that 5500 lbs tractors are checking out. Whats to say that hasn't gotten heated up? They run a water line but I still don't know. I think the guys running the big ones should wait until AFTER they pull to dyno out like all the others do. If they are that close on hp they should hang it up, but I think its more of an ego thing than anything.
