Continental Rod Strength
Going to Blow?
10-03-2007 12:00:57
How well do the Continental (176?) connecting rods hold up in the big stroke (6") slow running (stock rpm +20%) Oliver 88 engines? At what power level do they start failing?
Going to blow?
10-04-2007 09:38:52
 Re: Continental Rod Strength in reply to Going to Blow?, 10-03-2007 12:00:57
That was what I thought. Thank you for the feedback.
stroker 88
10-03-2007 18:18:37
we used farmall A rods in our first one. they didn't fail. but billet is the correct way. also allows you to use a larger rod pin diameter.
Don't risk it...
10-03-2007 13:31:32
Go billet BEFORE you have a problem, or you'll soon have a see-through block!
Ian Johnsen
10-03-2007 21:51:11
 Re: Continental Rod Strength in reply to Don't risk it..., 10-03-2007 13:31:32
Motor windows are COOL!.....well, when they belong to someone else.
