2-cylinder positive trac, limited slip for rearend
JD Pullin'
10-03-2007 07:06:24
Does anyone have any ideas or setups to tighten up the differential on a JD G. I don't want a locked in positve rearend I can't turn, just a way to get more positive traction, limited slippage. I don't want to have to ride the brakes and kill my horsepower just to keep the tires hooked together. Thanks.
jd b puller
10-03-2007 21:50:39
 Re: 2-cylinder positive trac, limited slip for rearend in reply to JD Pullin', 10-03-2007 07:06:24
Nothing against people that sell limited slip, but save your money and buy a crank. Use your brakes. If you start to lose power, let up on the brakes. If you're losing power, you probably aren't spinning the tires much.
Earl - IL
10-03-2007 16:49:05
Chad & Earl in Indiana has a good set up . Limited slip. They have a add in the Hook. Earl In Illinois
