dyno
smdv806
10-02-2007 09:05:50
What does a good dyno cost these days? Would it be possible to make a couple extra dollars by showing up with one at a tractor pull and charging $10 a reading?
JOE ZIP
10-02-2007 09:27:22
 Re: dyno in reply to smdv806, 10-02-2007 09:05:50
Possibly, however most pullers have removed the PTO for weight purposes. A lot of the tractor shows have them but I've never seen them charge for using one. But they might in other areas.
As for price, I gave $250.00 for mine but $600.00 is common for one that usually needs a little work I've seen them go for a lot more though. Depends on the shape it's in, mine just needed two holes repaired in the cooler, I got lucky. Look around some of the older dealers, mine was sitting out back where I get my hay equipment.
Jim
